Page 1 of 3 1 2 3
WIRING NIGHTMARE..............NEW IDEA! #1303185
09/12/12 11:35 PM
09/12/12 11:35 PM
State of confusion
Thumperdart Offline OP
State of confusion
Being sober and checking out some of my wiring I did a few years ago w/several drinks in me makes me question a few things here. My wiring skills are weak so bear w/me..........Seems I tied several hot wires into my fuse box and not too cleanly and the rest of my big pos. feed wires go directly to my ford relay under the dash so, can I tie all of the wires at the fuse box to the ford relay also? Actually there`s no room left on the pos. post so what would you guys do? Thankxxxx
Re: WIRING NIGHTMARE............................ [Re: Thumperdart] #1303186
09/12/12 11:38 PM
09/12/12 11:38 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
use a "buzz bar"
common feed in with multiple outlets.any sparky or auto elec shop.maybe NAPA.should be able to supply
just love wiring .about to rewire a dash in a 68 barracuda
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: WIRING NIGHTMARE............................ [Re: tex013] #1303187
09/12/12 11:41 PM
09/12/12 11:41 PM
State of confusion
State of confusion
So then can I run a big lead off of the relay to the buzz box and call it good?
Re: WIRING NIGHTMARE............................ [Re: Thumperdart] #1303188
09/12/12 11:45 PM
09/12/12 11:45 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
that is what i do,you can then run inline fuses per item or a circuit breaker to the buzz bar.Or you just use an aftermarket fuse box - same effect
Tex
New best MPH 130.32
Re: WIRING NIGHTMARE............................ [Re: tex013] #1303189
09/12/12 11:50 PM
09/12/12 11:50 PM
State of confusion
State of confusion
Thankxxxx Tex.............I plan to rewire the whole car someday soon and will replace EVERYTHING under the dash since firewall foreward is good to go.
Re: WIRING NIGHTMARE............................ [Re: Thumperdart] #1303190
09/13/12 12:01 AM
09/13/12 12:01 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
hey thumpper just have an 18 pack and have another look every thing will look normal are you going to make the next nmca race at bakersflield
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: WIRING NIGHTMARE............................ [Re: WHITEDART] #1303191
09/13/12 01:29 AM
09/13/12 01:29 AM
State of confusion
State of confusion
No chit........ It`s been over 100 days and I`m scared to drink now no joke. When is that race? I was shootin for Nov. 3rd for the t&t..............
Re: WIRING NIGHTMARE............................ [Re: Thumperdart] #1303192
09/13/12 11:20 PM
09/13/12 11:20 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I am wiring up my car now........I found some Buss bars on ebay from a marine outlet and they had two kinds.....with fuse holders ( glass fuses ) and without. I am powering my relays with the fused one and using the other for low current stuff like the line lock and the switches for the relays.
The name of the joint was Great Lakes supply I think , but I am not at the casa to double check.
Pretty nice stuff and not a ton of money.
Gotta add ....... congrats on 100 days.
I know I have certainly done worse things with my life than putting down the juice.
Re: WIRING NIGHTMARE............................ [Re: tubtar] #1303193
09/13/12 11:30 PM
09/13/12 11:30 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Use a fuse block from Blue Sea or Buss and Run a #10 wire from the ford relay to the main post on the fuse block. That way you can fuse the line lock, ignition, etc. You can get fuse blocks that hold 4, 6 , 8, 10, or even more fuses.
http://www.wiringproducts.com/contents/e...CFWdxQgodxHcAJQ
You can also buy fuse blocks with a ground bus so one big ground wire can be ran to the battery/body/whatever and all of the stuff you have powered can have ground that land in the same place.
Hope that helps, let me know if you need part numbers. Get some wire labels too, it makes trying to figure out exactly what the hell you were doing six years ago much easier. DAMHIK!
Re: WIRING NIGHTMARE............................ [Re: tubtar] #1303194
09/13/12 11:32 PM
09/13/12 11:32 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
They make them with the newer (than the twist) plastic blade type ATO/ATC fuses as well. For the big stuff I use thermal circuit breakers that will shut off and be usable once reset if the problem is repaired.
Re: WIRING NIGHTMARE............................ [Re: tubtar] #1303195
09/14/12 12:21 AM
09/14/12 12:21 AM
State of confusion
State of confusion
Thankxxx guys.......... Wish I could completely wire the whole car but I`m putting my friends 67 big block 4-speed Mustang together from a bare shell up and it`s killin me. This thing was in body shop jail for almost 5 years and the guy told him he spent his money on coke and laughed in his face. Took me 2 hrs. just to figure out how to install one back window and it will leave here complete and running w/a freshly built 480-500 hp 390 so maybe after that......... In the mean time I`ll check out the fused busses IF that`s the best route. Thankxxx for the not drinking kudos........much appreciated.
Re: WIRING NIGHTMARE............................ [Re: tex013] #1303196
09/14/12 02:23 AM
09/14/12 02:23 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
use a "buzz bar"
Tex
Tex, its a BUSS bar, usually a 1/8" piece of copper strip 1/2" wide as long as you need it, then drill to fit #10-32 threads and screw your wires down. You need a stand off to insulate it, used in the aircraft industry a lot. Tim
Re: WIRING NIGHTMARE............................ [Re: astjp2] #1303197
09/14/12 09:29 PM
09/14/12 09:29 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I cleaned up about 2/3 of my "rats nest" w/a buzz bar and a stand alone fuse block and used those blade type fuses that glow when they blow. It looks a lot better. Get a buzz bar w/ lots of terminals. You'll be suprised how many you use.
I'm considering a installing another bar for grounds.
Yeah, it's got a smallblock.
Re: WIRING NIGHTMARE............................ [Re: 340B5] #1303198
09/14/12 10:27 PM
09/14/12 10:27 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I just rewired my nightmare recently when I installed my 6al-2 using a buzz bar. I wired mine too with my old friend Pabst originally, I can't beliveve it made it as far as it did lol. Been sober a year now and I've found alot of nice things I've done while under the influence.
Re: WIRING NIGHTMARE............................ [Re: SLOW67] #1303199
09/14/12 10:49 PM
09/14/12 10:49 PM
State of confusion
State of confusion
I`ll start by just fixing the immediate problem then rewire the the car from the firewall back maybe over the winter. Thankxxx.........
Re: WIRING NIGHTMARE............................ [Re: Thumperdart] #1303200
09/15/12 01:06 PM
09/15/12 01:06 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Another thought; Make yourself a wiring diagram when you do re-wire. You'll thank yourself later.
Re: WIRING NIGHTMARE............................ [Re: 340B5] #1303201
09/15/12 01:13 PM
09/15/12 01:13 PM
State of confusion
State of confusion
Good idea.......... Plus everything will be labeled.
Re: WIRING NIGHTMARE............................ [Re: 340B5] #1303202
09/15/12 04:03 PM
09/15/12 04:03 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
When you have a diagram you can run a bundle out at one time and not string it out one wire at a time.
My use many colors
size the wire and circuit protection (fuse or cir. breaker) for the load
use relays for heavy loads ( fan, big fuel pump, etc)
keep it as simple as possible so it is easy to fix at the track in a hurry when something fails
take you time and buy good parts
"Just a Bracket car dressed up like a streetcar"
Re: WIRING NIGHTMARE............................ [Re: Just-a-dart] #1303203
09/15/12 05:54 PM
09/15/12 05:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Tip: check your local hardware store in the home electrical area for boxes of uninsulated terminals. They're nice for soldering to the wires and covering with shrink tube. Looks more professional and has less resistance than crimp-on connectors, and in many cases they're less expensive. Same deal on butt-splices where the wire is sleeved or you don't want a visible extension of the wire.
Re: WIRING NIGHTMARE............................ [Re: topside] #1303204
09/15/12 06:07 PM
09/15/12 06:07 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
What he said...and dip the stripped wire ends in no-ox compound...
http://www.diversitech.com/Product-Sub-Category?id=a04C000000JpCspIAF
Page 1 of 3 1 2 3
